White smoke
150 MILES • 4.7L • V8 • 4WD • AUTOMATIC
GLORIA ESPANIO
White smoke comes out of my muffler. why is this happening? it has oil inside the muffler, it did not overheat and I am not losing coolant.
Mar 1, 2018 at 12:31 PM
Good evening.
White smoke is an indication of burning coolant. You may have a leaking head gasket.
I suggest you get someone to do a leak down test on all the cylinders to be sure there is no damaged head gasket. It is the common reason for this issue.
Mar 2, 2018 at 9:15 AM
