White smoke and engine shuts off when stopped
268,000 MILES • 5.3L • V6 • 4WD • AUTOMATIC
APRIL TAYLOR SEIF
  • 23 POSTS
Runs but when stopped it shuts off. White smoke comes out of tail pipe.
Jun 7, 2020 at 2:18 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
White smoke usually denotes a head gasket issue.This means the head gasket has failed and now engine coolant is being burned during the engines combustion process.It's a fixable repair but is costly. I've also noticed your truck has 268,000 miles so a $2,000.00 repair on an engine with that high of a mileage must be taken into consideration. Here is a tutorial for you to view:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Let me know if you have any further questions on this issue.Hope this helps and thanks for using 2CarPros.
Jun 7, 2020 at 3:03 PM
APRIL TAYLOR SEIF
  • 23 POSTS
Planned on doing it myself.
Jun 7, 2020 at 3:06 PM
DANNY L
  • 5,648 POSTS
Hello again.
Would you like for me to provide step by step picture instructions for you? Thanks again for using 2CarPros.
Danny-
Jun 7, 2020 at 3:11 PM
APRIL TAYLOR SEIF
  • 23 POSTS
Yes please.
Jun 7, 2020 at 3:20 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is part 1. I've attached picture steps below for removal and install of the intake manifold below.Here is a tutorial showing how to replace intake manifold gaskets:
https://www.2carpros.com/articles/replace-intake-manifold-gasket
Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 7, 2020 at 4:35 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is part 2 left side. I've attached picture step instructions again below for the cylinder head removal and replacement for the head gaskets.Hope this all helps.
Jun 7, 2020 at 5:00 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the final part 3 right side. I've attached picture step instructions again below for the cylinder head removal and replacement for the head gaskets.Let me know if you have any further questions about all of this.Hope this all helps.
Danny-
Jun 7, 2020 at 5:14 PM
APRIL TAYLOR SEIF
  • 23 POSTS
Do I have to change 4 head gaskets on this?
Jun 9, 2020 at 12:54 AM
DANNY L
  • 5,648 POSTS
Hello again.
No, each cylinder head has only one gasket. The intake manifold has one gasket per side as well.Let me know if you have any further questions about this considering this is a very big job.Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 9, 2020 at 11:35 PM
