White smoke out of tail pipe
200,000 MILES • 1.2L • 6 CYL • AUTOMATIC
TRACY SMITH2
Suddenly a lot of white smoke coming from tail pipe. Is not getting hot and drives fine. What should I look at for the problem?
Aug 12, 2018 at 9:06 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
White smoke usually indicates coolant being burnt in the engine combustion chamber. So, remove all the spark plugs and inspect for coolant on any. If found that is the cylinder that is leaking the coolant into it and most likely a blown head gasket.
If you cannot find any coolant on any spark plugs, complete a compression test. If one cylinder is really low, that too would mean the head gasket is leaking.
Aug 13, 2018 at 2:09 AM
