White smoke
20,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
ADIEADAMSON
Clouds of white smoke after cold start and for about five miles.
May 31, 2019 at 11:04 PM
Good morning,
White smoke is an indication of burning coolant. It can come from a head gasket or an intake manifold gasket.
https://www.2carpros.com/articles/replace-intake-manifold-gasket
You will need to have a leak down test done to determine if a head gasket is the failure.
What has been checked so far?
Jun 1, 2019 at 12:20 AM
ADIEADAMSON
I have done a block test, that was fine, The car is nine year old and the genuine mileage is 13,000. I bought it six months ago, not sure if this problem could have be caused by lack of use?
Jun 1, 2019 at 2:14 AM
No, you need to do a leak down test. The block test is not accurate at all. That is when you remove the plugs and add shop air into each cylinder one at a time and watch for coolant movement in the radiator. That is the only accurate check for a failed head gasket.
Jun 1, 2019 at 4:40 AM
