I have done a block test, that was fine, The car is nine year old and the genuine mileage is 13,000. I bought it six months ago, not sure if this problem could have be caused by lack of use?
Jun 1, 2019 at 2:14 AM
✓Experienced Mechanic
No, you need to do a leak down test. The block test is not accurate at all. That is when you remove the plugs and add shop air into each cylinder one at a time and watch for coolant movement in the radiator. That is the only accurate check for a failed head gasket.
Jun 1, 2019 at 4:40 AM
