white color exhaust
100,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
YOSEF LEVY
  • 7 POSTS
Hello
I have a car suzuki euroswift sedan
engine G13B
VIN TSMMAH35S30892734
engine oil level normal (between high and low)
engine oil consumption : ~400cc each 400Km
water coolant consumption - exists - (hole in radiator)
I see white color exhaust at startup and reduce after engine running
but still suspect color to high
liquid from exhaust with no smell
any idea what is the cause ?
Rgds.
https://drive.google.com/file/d/1CKy8TxT9BJMb74fpoXoHvg6vHKCv6_1K/view?usp=sharing
https://drive.google.com/file/d/1CLXrudY3IxMlHxRWC0z_sFgcILLpjZxw/view?usp=sharing
May 28, 2023 at 11:37 PM
  • 55,711 POSTS
It sounds like you have a blown head gasket, does the white smoke go away after the engine has been heated up to operating temperature?
Here are guides that can help confirm the problem:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
and
Thanks for the videos, they help. Please go over these guides and get back to us.
May 30, 2023 at 4:49 AM
