Codes p0174 and p01751
184,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JOAHUALEEADAMS
Thanks for taking the question.
So here goes.
Truck pours out white smoke for ten minutes when driving whether hot or cold
Step on gas and it blows black smoke.
Replaced up o2, map sensor, coils and plugs and manifolds.
Spark plugs on passenger side of engine get black and destroyed quick.
Sometimes will miss driving down road at highway speed.
Throws codes p0174 and p01751 which one in too lean and one it too rich.
My mechanic has no clues any ideas?
Jan 24, 2018 at 9:47 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Does this have dual exhaust and if so, is this smoke coming out both tailpipes?
If this has a y pipe it will not matter.
The white smoke I think we can assume is a blown head gasket and coolant being burned.
The black smoke is the rich fuel mixture.
Also, you have too many digits in that one code p01751, it should be P0175.
For starters, check the fuel pump pressure. It should be 59 psi +/- 5 psi.
Do you have access to a scan tool that can read o2 voltages and map sensor barometric pressure and vacuum value?
Jan 24, 2018 at 10:00 PM
JOAHUALEEADAMS
Yeah, I just added an extra digit by mistake. It is single exhaust. Whenever I put new plugs in it the white smoke goes away for a few days.
I think my scanner does live data.
Jan 25, 2018 at 1:23 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I have heard of raw gasoline burning making white smoke, but I personally do not recall that.
That would make sense though since you also have the black smoke and the too rich fuel mixture.
Did you check the fuel pressure yet?
This is why I asked about that live data, if you want to perform this.
p0175
Diagnostic Test
1) ACTIVE DTC
NOTE: Check for contaminates that may have damaged an O2 Sensor: contaminated fuel, unapproved silicone, oil and coolant.
Start the engine.
Allow the engine to reach normal operating temperature.
With a scan tool, select View DTCs.
NOTE: It may be necessary to drive the vehicle to meet the conditions to set this DTC, try to repeat the conditions in which the fault originally set by reviewing the Freeze Frame data.
Is the DTC Active or Pending at this time?
Go to 2).
Refer to INTERMITTENT CONDITION .
2) CHECKING FUEL PRESSURE
WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released. Failure to follow these instructions can result in personal injury or death.
Install a fuel pressure gauge to the fuel rail.
Ignition on, engine not running.
With the scan tool, actuate the ASD Fuel System test and observe the fuel pressure gauge.
NOTE: Fuel pressure specification is 407 kPa +/- 34 kPa (59 psi +/- 5 psi).
Turn the ignition off.
Choose a conclusion that best matches your fuel pressure reading.
Within Specification
Go to 3).
Above Specification
Replace the fuel filter/pressure regulator.
Perform POWERTRAIN VERIFICATION TEST .
CAUTION: Stop All Actuations.
3) O2 SENSOR OPERATION
Start the engine.
NOTE: If one of the O2 Sensors Signal or Return circuit is shorted to ground or voltage, all the other O2 Sensor voltage readings will be affected.
NOTE: After the repairs have been made, verify proper O2 Sensor operation. If all the O2 Sensor voltage readings have not returned to normal, follow the diagnostic procedure for the remaining O2 Sensors.
With the scan tool, monitor the 2/1 O2 Sensor voltage reading.
Is the voltage switching between 2.5 and 3.4 volts?
Go to 4).
Go to 9).
4) 2/1 O2 SENSOR HEATER OPERATION
NOTE: Wait a minimum of 10 minutes to allow the O2 Sensor to cool down before continuing the test. Allow the O2 Sensor voltage to stabilize at 5.0 volts.
With the scan tool, perform the 2/1 O2 Heater Test for each O2 Sensor.
With the scan tool, monitor the 2/1 O2 Sensor voltage while performing the Heater test for at least 2 minutes.
Does the voltage stay above 4.5 volts for each Sensor?
Replace the 2/1 O2 Sensor.
Go to 5).
5) MAP SENSOR OPERATION
With a scan tool, read the Barometric Pressure.
NOTE: The Barometric Pressure should be approximately equal to the actual barometric pressure. If necessary, compare the Barometric Pressure value of this vehicle to the value of a known good vehicle of a similar make and model.
Connect a Vacuum Gauge to a Manifold Vacuum source.
Start the engine.
Allow the engine to idle.
NOTE: If engine will not idle, maintain a constant RPM above idle.
With the scan tool, read the MAP Sensor vacuum value.
Is the scan tool reading for MAP Vacuum within 1 inch of Hg on the Vacuum Gauge reading and is the Barometric Pressure reading of the vehicle the approximately the same as actual Barometric Pressure?
Go to 6).
Replace the MAP Sensor.
NOTE: Remove the vacuum gauge before continuing.
6) ECT SENSOR OPERATION
NOTE: For this test to be valid, the thermostat must be operating correctly.
NOTE: This test works best if performed on a cold engine (cold soak).
With the scan tool, read the Engine Coolant Temperature Sensor value. If the engine was allowed to sit overnight (cold soak), the temperature value should be a sensible value that is somewhere close to the ambient temperature.
NOTE: If engine coolant temperature is above 82° C (180° F), allow the engine to cool until 65° C (150° F) is reached.
Start the Engine.
During engine warm-up, monitor the Engine Coolant Temperature value. The temp value change should be a smooth transition from start up to normal operating temp 82° C (180° F). The value should reach at least 82° C (180° F).
Did the ECT value increase smoothly and reach at least 82° C (180° F)?
Go to 7).
Replace the Engine Coolant Temperature Sensor.
7) EVAP PURGE SOLENOID OPERATION
Disconnect the hoses at the Evap Purge Solenoid.
Using a hand vacuum pump, apply 10 inches of vacuum to the Evap Purge Solenoid vacuum source port on the component side.
Did the Evap Purge Solenoid hold vacuum?
Go to 8).
Replace the EVAP Purge Solenoid.
NOTE: Connect the vacuum hoses before continuing.
8) ENGINE MECHANICAL
Check for any of the following conditions/mechanical problems.
AIR INDUCTION SYSTEM - must be free from restrictions.
ENGINE VACUUM - must be at least 13 inches in neutral
ENGINE VALVE TIMING - must be within specifications
ENGINE COMPRESSION - must be within specifications
ENGINE EXHAUST SYSTEM - must be free of any restrictions or leaks.
ENGINE PCV SYSTEM - must flow freely
TORQUE CONVERTER STALL SPEED - must be within specifications
POWER BRAKE BOOSTER - no internal vacuum leaks
FUEL - must be free of contamination
FUEL INJECTOR - plugged or restricted injector; control wire not connected to correct injector
Are there any engine mechanical problems?
Repair as necessary.
Go to 12).
9) 2/1 O2 SENSOR
Fig 2: Checking O2 Sensor Return Upstream & Downstream Circuits
GC0038466
Courtesy of CHRYSLER LLC
Disconnect the 2/1 O2 Sensor harness connector.
With the scan tool, monitor the 2/1 O2 Sensor voltage.
O2 Sensor voltage should read between 4.1 and 5.0 volts on the scan tool with the connector disconnected.
Connect a jumper wire between the (K43) O2 Sensor 2/1 Signal circuit and the (K902) O2 Return Upstream circuit in the O2 Sensor harness connector.
NOTE: The voltage should drop from between 4.1 and 5.0 volts down to 2.5 volts with the jumper wire connected.
Did the O2 Sensor voltage drop from between 4.1 and 5.0 volts to 2.5 volts when the jumper wire was installed?
Replace the O2 Sensor
Go to 10).
NOTE: Remove the jumper wire before continuing.
10) O2 SENSOR SIGNAL CIRCUIT
With a scan tool, monitor the 1/1 O2 Sensor voltage readings with the jumper wire removed.
NOTE: The scan tool will display all O2 Sensor voltage readings approximately 5.0 volts when only one O2 Sensor's Signal circuit is shorted to voltage.
NOTE: The scan tool will display one O2 Sensor voltage close to zero and the others will read lower than normal when one O2 Sensor Signal circuit contains excessive resistance.
Is the voltage between 4.1 and 5.0 volts?
Go to 11).
Check the (K43) O2 Sensor 2/1 Signal circuit for damage, short to ground, open, or short to voltage. Inspect the O2 Sensor connector and the PCM harness connector. If OK, replace and program the Powertrain Control Module per Service Information.
11) (K902) O2 SENSOR RETURN UPSTREAM CIRCUIT
Fig 3: Checking O2 Sensor Return Upstream & Downstream Circuits
GC0038465
Measure the voltage on the (K902) O2 Return Upstream circuit in the O2 Sensor harness connector.
Is the voltage at 2.5 volts?
Go to 12).
Check the (K902) O2 Return Upstream circuit for damage, short to ground, open, or short to voltage. Inspect the O2 Sensor connector and the PCM harness connector. If OK, replace and program the Powertrain Control Module per Service Information.
NOTE: Turn the ignition off before continuing.
12) POWERTRAIN CONTROL MODULE (PCM)
Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the 2/1 O2 Sensor and the Powertrain Control Module (PCM).
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals. Verify that there is good pin to terminal contact in the 2/1 O2 Sensor and Powertrain Control Module connectors.
Refer to any Technical Service Bulletins that may apply.
Were there any problems found?
Replace and program the Powertrain Control Module per Service Information.
Jan 25, 2018 at 1:41 AM
