Whistling for no reason
160 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
RAGAZZO
Please watch up the video. Every thirty minutes exactly during my driving start this whistle for a reason that I do not understand.
Nov 25, 2017 at 3:33 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Are you referring to the warning buzzer?
Is that a check engine lit up on the instrument cluster?
Nov 25, 2017 at 4:00 AM
RAGAZZO
Yes, I am referring the buzzer noising that you hear in the video posted. Please do not pay attention to the engine light up, that has been on since I bought it. It is a fake contact. I need to resolve the buzzer please. Thank you.
Nov 25, 2017 at 8:48 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It is hard to tell just by the noise. Perhaps if there was also a warning light to go along with it, but then again you would probably already know it then. Is perhaps the warning light out? Turn off the engine, then turn the key just to run and see if all the lights come on for bulb check and post another video showing all the lights on the instrument cluster coming on for bulb check.
If you still cannot figure it out, perhaps removing the fuses or relays know to be for the warning buzzers to try to narrow it down to which then see what is wrong and why it is making the noise and if also the bulb is burned out or what. If you have not already done so, try buckling the seat belt, try tightening the gas cap, stuff like that, too.
Nov 25, 2017 at 11:15 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Is this a hybrid?
Nov 25, 2017 at 11:16 PM
