CV Axle Replacement
KHLOW2008
  • 41,814 POSTS
For this model, the shaft is rather tight and quite often we have difficulty removing the shaft.
Something is not correct and it could be the length of the joint that plugs in.
If your old shaft is still available, compare their length.
Did you compare the length of the complete shaft before installing?
Remoe the central locking nut and push the sgaft as far as it can go in. The tip of the shaft should be almost completely level with the hub flange. If it is going in further than that, the length of the shaft could be too short.
Monday, February 15th, 2021 AT 1:03 PM (Merged)
  • 31,937 POSTS
I would be fitting a new "C" retaining clip on the shaft.
THA_JUGGALA
  • 9 POSTS
Khlow2008 I matched the two up when I got the new one but I no longer have the old one
mhpautos the shaft is new the clip is in normal condition I dont think that is the problem
can anyone tell me what the noise is it sounds like its coming from the passenger side of the tranny or where the cv connects to the tranny
KHLOW2008
  • 41,814 POSTS
Some C-clips are not strong if it is not OEM so I agree with mhpautos about replacing it.
What type of noise are you getting?
When does the noise occur?
THA_JUGGALA
  • 9 POSTS
Its a clicking sound when the car is moving rather if its on or not it dose it while in motion
KHLOW2008
  • 41,814 POSTS
Does it occur on straight lines or only when making turns?
THA_JUGGALA
  • 9 POSTS
Strait lines
KHLOW2008
  • 41,814 POSTS
Straight line noises are usually caused by axle shafts or wheel bearings.
Are the axle shafts rebuilt or completely new?
If rebuilt, you could have a bad bearing inside the joints.
THA_JUGGALA
  • 9 POSTS
One is rebuilt the other is new
  • 31,937 POSTS
Have you made absolutely sure that the outer shaft is fully located in the hub and the nut is the correct torque?
SUZUKIGIRL
  • 1999 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 200,000 MILES
Just replaced front passenger CV axle. How can I know if the CV axle shaft has been installed properly into the transaxle without driving it? Afraid to test it and break something if not fully inserted.
THA_JUGGALA
  • 9 POSTS
Yes I have
CARADIODOC
  • 33,916 POSTS
The inner CV joint is spring-loaded to hold the housing into the transmission. If it was not fully inserted, you wouldn't have been able to reconnect the lower ball joint. Once everything is assembled, but just before you install the axle nut, press in on the outer CV joint's stub shaft with your thumb. It should take significant effort, but it will move in a good half inch, then it will pop back out under that spring pressure.
The most common mistakes with this job have to do with that axle nut. It must be tightened to specs with a click-type torque wrench, and it absolutely must be tightened before any vehicle weight is set down on the tire. Failure to do either of those will instantly make the wheel bearing noisy. Many do-it-yourselfers set the vehicle on the tire to hold the axle shaft from spinning when they try to tighten the nut. Instead, just drop a punch or screwdriver into one of the cooling slots in the rotor before the wheel is installed, then tighten the nut. The torque spec is 217 foot pounds.
You might find some more information in this article:
https://www.2carpros.com/articles/replace-cv-axle
KHLOW2008
  • 41,814 POSTS
Apart from weak C-clips, the other possibilities are :
1. Incorrect shaft, could be the length of the joint is too short. After pushing in the joint, check if it is easy to get dislodged when you pry at it gently. You should have a feeling of the clip in position.
2. The differential is bad. The housing for the shaft is worn/bad resulting in the C-clip not holding the shaft in position. If the complete shaft is too short, the inner joint would more likely to separate from the shaft rather than the inner joint coming out.
Monday, February 15th, 2021 AT 1:04 PM (Merged)
SUZUKIGIRL
Okay, sounds like I got it right. Thank you so much for your assistance. I appreciate you.
  • 31,937 POSTS
Time to check the inner spline in the trans axle for wear or damage, the only thing that holds the shaft in is the "C" clip, so the problem will be in that end, I would also put the car on a hoist and check for any movement in the position of the shaft end with the steering on full lock, make sure that there is nothing causing the shaft to tension up with an outward tension on lock causing the clip to disengage.
