Whirling noise
117,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • AUTOMATIC
AUSTINHEATHER1997
I have a whirling noise that I can't seem to find what it is. I heard it and immediately thought wheel bearing. However, I got my wheels rotated and balanced and the sound followed the wheel, so then I thought tires. It's been to two different shops, and I have been told the tires are fine (they have about a year of normal commute driving on them) so I am clueless as to what the noise is. It is speed dependent; at low speeds I can barely hear it. I hear it the most when deaccelerating on smooth roads. Any help would be greatly appreciated.
Mar 23, 2022 at 6:23 AM
SQM
  • 6,383 POSTS
Since the noise moved when you did the tire rotation, logic says it is the tire. It is possible that the tire is good but has a spot or an imbedded rock on the tread that is causing the noise.
With what you are explaining the issue is likely with the tire.
https://www.2carpros.com/articles/how-car-tires-work
Mar 23, 2022 at 8:40 AM
