Whinning noise and wont move
60,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
EDDY1991
  • 44 POSTS
I have a Xtronic CVT.
Before few days my car's CVT transmission belt broke. I purchased the belt with both the pulleys and valve body.
I drove the car for around six miles later on it stop accelerating and whining noise appears. Now it completely wont move and whining noise is still there. The transmission oil is clean.
There is no error in shifting.
Nov 13, 2016 at 7:59 PM
KOOLCADDY6
  • 60 POSTS
You should contact your Nissan dealer I read they were extending the warranty on those CVT transmissions for similar problems.
Nov 13, 2016 at 11:47 PM
HMAC300
  • 48,601 POSTS
check fluid level then check for adjustment. after that start engine and see if you can feel anything when shifting to different gears. it may be the torque converter finally check line pressure. if this is all good have a transmission professional look at it.
Nov 13, 2016 at 11:49 PM
EDDY1991
  • 44 POSTS
sir,
can we check the pressure by removing the hose of the transmission which is just above the oil pan?
Nov 14, 2016 at 12:21 AM
EDDY1991
  • 44 POSTS
car is not moving at all and the voice increase while giving gas in neutral or in gear.
Nov 14, 2016 at 12:56 AM
HMAC300
  • 48,601 POSTS
no, you cannot do it off of the hose that is cooling line pressure. See picture for line pressure and forward clutch, but from your description something has broken like a planetary carrier inside transmission.
Nov 14, 2016 at 2:20 AM
