whining noise
2006 CHRYSLER TOWN AND COUNTRY
110 MILES • AWD • AUTOMATIC
SHELLY RAWLINGS
Whining noise, no leaks. I changed the power steering reservoir. It still whines when setting in park and when driving I have not had a problem with steering
Jul 24, 2016 at 10:39 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
make sure you use power steering fluid not transmission fluid as a lot of auto parts people say it is the same which it is not. the noise may be a loose belt and or the valve in pump has to much clearance causing it, which wont hurt anything. you may have air in system as well which if you turn to lock one way and hold it for thirty seconds then do the same in opposite direction. repeat this ten times and it may go away.
Jul 24, 2016 at 11:33 AM
