Whining when in gear
140,000 MILES • 3.7L • 6 CYL • 4WD • MANUAL
RICHARDK0486
Whining noise when driving. I jacked car up and once I put it in gear there is a whining coming from under. Cannot pinpoint if it's in the drive-train or gear box. With tires off ground i put it in gear I hear it and not when idling. When shifting to higher gears it gets louder and more prominent. I checked rear differential fluid and it is full only. Also last few months the shift knob has been popping of gear sometimes at take off. My car has 140,000 miles. My car has a manual transmission.
Oct 23, 2016 at 10:34 PM
HMAC300
  • 48,601 POSTS
it may either be gear noise or maybe if cable operated not going into gear all the way. or a bad synchro. Best thing is to check transmission fluid and see if full it may be time for a rebuild on it.
Oct 24, 2016 at 12:14 AM
