Whining noise from engine area and squealing noise from A/C
2006 MERCEDES BENZ C230
145,126 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
GOGYALE85
Whining noise while in idle and accelerating. Replaced idler pulleys, belt tension-er and tension-er pulleys and power steering pump. Noise still there. My A/C is squealing but i cannot remove the two screws from plastic cover to check the blower motor. what did you use to remove them in the video?
Mar 31, 2018 at 3:06 PM
  • 55,224 POSTS
So is this two different noises or the same noise? Can you take a quick video and upload it here so I can hear the noise so I do not have to guess?
Cheers, Ken
Apr 3, 2018 at 4:07 AM
