Whining noise and shifting issue
250,700 MILES
EINSTEINJS
I have a 1999 Infiniti QX4 with 250,700 miles. I had the transmission replaced about 2 months ago... it is the second time... recently, it has been making a whine noise when accelerating. i heard it once a few weeks ago and figured I had just never paid attention before... then it got worse when i noticed it again a few weeks later. The pitch of the whine follows the RPM range... Also when i got the car back, when shifting, you could definately feel it shift from gear to gear. This morning when I drove it, as stupidly as this sounds, now it is shifting too smooth... when the rpms shift back, it seems slow and you hardly feel it shift now. when it is shifting full throttle, it hesitates a little as well, but slowly shift to the higher gear... what could be causing these?
Apr 25, 2013 at 3:30 AM
HMAC300
  • 48,601 POSTS
it could be a valve hanging up occasionally. if this was rebuilt take it back as it should be under warranty. the whine cold be anything from a planetary gear bearing gone bad or going bad to a torqueconverter so if it was rebuilt then take it back they should fix this no cost
Apr 25, 2013 at 5:04 AM
EINSTEINJS
Thanks! I've already called them to tell them I'm bringing it this afternoon... Yes, it is under warranty. I will let you know what they find :)
Apr 25, 2013 at 5:21 AM
