Whining after new clutch
189,000 MILES • FWD • MANUAL
SUSAN GUSTAVSON
I just had a new engine and a new clutch installed and now the car whines, except when the clutch is depressed. Is this serious, is it related to the new clutch, can I drive it for now?
May 7, 2016 at 10:28 AM
  • 31,937 POSTS
sounds as if the clutch thrust bearing is faulty, take it back to the mechanic that installed it and get them to listen to the noise, they should be doing this under warranty if it is the thrust bearing.
May 7, 2016 at 10:51 AM
SUSAN GUSTAVSON
Thank you so much!
May 7, 2016 at 11:05 AM
SUSAN GUSTAVSON
One quick question, could I drive it for a couple of days without damaging something?
May 7, 2016 at 11:07 AM
  • 31,937 POSTS
okay, but get it checked asap as it may seize and damage the clutch, thank you for using 2carpros.
