Whine in Front End
160,000 MILES
MADMOOSE
  • 18 POSTS
Suburban now has 195K on it. About a week ago, it started making a whining noise in the front of the vehicle (while driving in 2wd) similar to the noise it usually makes when the 4wd is engaged. I thought I had lost the transfer case motor or the front actuator, but i checked both and they are engaging/disengaging fine. (I even jacked up the front end and confirmed this as well.) Had a bad left differential seal and left CV axle, so I had them replaced, but the whine is still there. Tires are older, but not worn abnormally.
It changes pitch with road speed, not engine speed. I also checked wheel bearings, but they are good. Seems to be coming from the front differential or thereabouts.
What would be the most likely culprit of this particular noise?
Thank you!
May 9, 2013 at 5:17 AM
HMAC300
  • 48,601 POSTS
as we can't hear it we are guessing. but move tires to rear and rear to front and see if it changes if it does it's tires. Tires should rotated every 7k check axle fluid as well.
May 9, 2013 at 5:56 AM
MADMOOSE
  • 18 POSTS
Would tire wear cause it to suddenly start making the noise (as it did), or would it be gradual? Axle fluid is good. Sound is from central front of car.
May 9, 2013 at 6:16 AM
HMAC300
  • 48,601 POSTS
you probably wouldn't recognize it at first just rotate tiers see what happens.
May 9, 2013 at 6:18 AM
