while driving and approaching intersection engine dies
220,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
VIJAY KUMAR
When coming to a stop the engine dies and will not start. After a while it starts again goes for 500 mtrs or sometime 5 to 10 km no problem then does same thing again. car mechanic has changed throttle body part which he thinks problem but problem not solved . previously i took to another mechanic he scanned it and says TCM Error but i forgot to note it down may be P001 and P002 if it makes sense in error code terms. It appeared on screen TCM (Transmission Control Module) Fault/2 but it would not clear even battery terminal removed reset through scanning device please help if anyone have solution . there was no engine light showing up prior to first scan. now engine light comes on after changing throttle body but problem remained same.
Nov 26, 2016 at 1:49 PM
HMAC300
  • 48,601 POSTS
Sorry, we have no information on this car as it is not sold here in US. those codes are not good here. if it is a U code then a mechanic has to find the problem with his scanner and see which module is the problem.
Nov 27, 2016 at 12:39 AM
