Hello, this fuse is located on the driver's side, side of the dashboard. I will see if I can find a picture of it, but it should be labelled Wiper Fuse 25Amp.
And just for your information, there is a Technical Service Bulletin on using fuses that are aftermarket or Not GM fuses. But I'm sure your local parts store will have decent fuses; this is talking about fuses bought at Harbor Freight.
Also, the wiper motor is on the same fuse as the washer pump motor, so if the wipers still work it's not the fuse. It can be the Ground wire for the washer pump motor or the wiper switch assembly, or the washer pump itself has failed.
The last diagram shows how to check the washer pump with a Multimeter or 12-volt Automotive test light.
Images (Click to enlarge)
Feb 15, 2022 at 4:12 AM
