Which car parts require more energy than the starter?
UTKU
Today, my car didn't start. I think that the crank was turning over because I could hear the loud sound a car makes just before starting up but the car was not starting. Anyways, I called for a mechanic. He changed the battery and the car works now. Coming to the point, I initially thought that since the crank was turning, there was no problem with the battery (like a weak battery) since I presume that turning over the crank requires a lot of energy. But in this case, it looks like there are parts in a car that requires even more energy than the starter motor, in the starting process of a car. So my question is, could you present a generic comparison of energy required per car part?
EDIT: Or am I completely out of the ballpark by thinking that there are parts that require more energy than the starter?
Thank you very much in advance
May 15, 2015 at 10:07 PM
  • 55,694 POSTS
The starter motor takes more amperage then any other part in the car, the noise your were hearing was problem the starter solenoid working due to low voltage.
Thanks for using 2CaPros.com
Best, Ken
May 23, 2015 at 3:13 AM
