Fuel pump location needed
230,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
BRENDA BRIGGS
Do I have to drop the gas tank to get to the fuel pump? on the car listed above (De Coupe)?
Sep 24, 2018 at 4:23 AM
  • 110,248 POSTS
The fuel pump is in the fuel tank. I believe the tank requires removal. However, under the rear seat, there is a large plug that can be removed. I believe it is only for the level sensor, but confirm that. It has been some time since I had one of these in my shop for repair.
Here is a link that shows general directions for pump replacement:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Here is a link that shows how to check a fuel pump (if needed):
Here are the specifications for pump pressure:
Curb idle, 38 PSI
Curb idle w/vacuum disconnected, 47 - 50 PSI
I have attached a picture of under the rear seat, where the plug is located. Also, I attached an exploded view of the tank and its components. It should help if the tank needs removed and as I mentioned, I feel confident it does.
Sep 24, 2018 at 11:14 AM
