Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
HHR
Drivetrain
Transmission
Input Shaft Sensor
where would the speed sensor be for a manel transmission?
2007 CHEVROLET HHR
198,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
OMAR GARCIA VALLE
MEMBER
my speedometer doesn't work nor do the digital readings in the gauge cluster, like average speed, pox mileage, current fuel economy.
Nov 17, 2020 at 2:17 AM
Experienced Mechanic
Sounds like you have a good idea on what the issue is as that is the most likely cause.
I attached the info for the vehicle speed sensor. Let us know if you need other info. Thanks
Images (Click to enlarge)
Nov 17, 2020 at 2:22 AM
OMAR GARCIA VALLE
MEMBER
Thank you so much. turned out the contour clip broke and popped out. got it all fixed now that you.
Nov 25, 2020 at 5:08 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
