Where the fuse box a relay fuse at?
10,000,000 MILES
ADAMDUGAN
I put new fuel pump in and now it won't start.
Nov 8, 2024 at 3:05 AM
  • 55,549 POSTS
I will help you, here are the locations for the fuse panels and fuel pump fuse. This guide should help you test the fuses:
The fuse panel is under the dash on the left side. Test the fuses with the key on. Check out the images (below). Let us know how it goes.
Nov 8, 2024 at 8:44 AM
