Code p0722, where is the output speed sensor located?
2016 CHEVROLET MALIBU
200,000 MILES • 4 CYL • AUTOMATIC
YADIER99
Hi, I have the car listed above Limited and it has the code p0722 low voltage in the transmission speed output sensor, I don't know where this sensor is located so I can check and replace it. Can you tell me where this sensor is located on this model?
Jun 29, 2023 at 4:28 PM
  • 110,244 POSTS
I need to confirm the engine size. There are four different 4-cylinder engines offered. Also, keep in mind, the output speed sensor can be internal and requires the removal of the valve body. They used different transmissions based on engine size, so I want to confirm the location first.
Jun 29, 2023 at 4:51 PM
