Where is the transmission range control sensor located?
375 MILES • V8 • 2WD • AUTOMATIC
GREGG86
Transmission in limp mode. i can put the car in drive but I can’t put car back in park unless I let up off the brake pedal.
Nov 17, 2024 at 4:46 AM
  • 110,246 POSTS
The transmission range sensor is on the valve body (inside the transmission). You can access it by removing the transmission oil pan.
See pics 1and 2 below. The remaining pictures are diagnostics (vague).
Let me know if this helps.
joe
Nov 17, 2024 at 1:28 PM
GREGG86
I changed the conductor plate in transmission still doing the same thing… I can take the car out of park into drive but can’t put it back in park unless I let up off brake pedal and I hear a clicking sound in shifter…
Nov 21, 2024 at 10:14 PM
GREGG86
And car is still in limp mode.
Nov 21, 2024 at 10:15 PM
  • 110,246 POSTS
If the park lock releases when the brake pedal is released, it sounds like something is wired backward. Has anyone done any work at the shifter? Also, have you scanned the entire can-bus?
Here is a link showing what I mean:
Nov 23, 2024 at 12:37 PM
