Windshield washer pump front and rear location
153,000 MILES
GARRY1955
Windshield washer pump front and rear location does not work need to replace.
Dec 3, 2018 at 10:43 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The rear pump appears to be attached to the washer container, so that will have to be removed. Same for the front.
THis video can help
https://youtu.be/ezjJz_N5cFQ
Check out the diagrams (Below). Please run this test and get back to us.
Dec 3, 2018 at 10:56 PM
CORY HALLBERG
i have a 2005 gmc envoy and the windsheild washer pump runs constantly. besides for pulling to fuze under the hood. what else could i do to get it to stop spaying
Oct 14, 2020 at 5:44 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello –
Not sure if you have fixed your vehicle yet.
Check the windshield wash relay…..tap on it or check to see if there is another relay just like it in the panel and swap them to see if this fixes the problem. Make sure it is the same relay though.
If it fixes it then the relay is bad – replace the relay.
IMPALASS
  • 3,112 POSTS
Hello –
Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
08089C
11/18/2008
Campaign - Deactivation Of Analog OnStar(R)
04109
12/15/2004
Campaign - PCM Replacement
06102B
10/19/2007
Recall - Aftermarket Leather Seat Cover Kit
05002
03/03/2005
Recall - Windshield Replacement
NHTSA05V035000
02/02/2005
Recall 05V035000: Windshield Replacement
SGREENE33
I have a 2003 GMC Enoy that will not pump washer fluid in the front since running the water out of the reservoir (replacing with windsheild fulid) in the fall. I have replaced the motor of the pump and replaced the fuse still with no fluid pumping and no noise of a running motor. The issues may be electrical. How do I test for power or any other ideas of cause?
DOCFIXIT
  • 18,828 POSTS
Does pump run? if yes need to prime hose. Get mouth full of water blow into hose till comes out sprayer then attach and operate
SGREENE33
The pump does not run.
DOCFIXIT
  • 18,828 POSTS
In under hood relay box find washer relay have helper operate washer does relay click?
