Where is the turn signal relay
145,000 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
TRAEBEN69
when I turn my turn signal on my cluster gauges go crazy and the light on the out side of the car does not work. I can hear and see them working on the inside of the van.
Apr 14, 2016 at 6:16 AM
  • 55,851 POSTS
The problem could be at the bulb that isn't working, please remove the bulb from the socket and retry the system while checking the bulb terminals to make sure they are not shorted internally. If okay the cluster is having a problem.
Apr 19, 2016 at 7:46 AM
