Hi and thanks for using 2CarPros.com. Your vehicle does not have a traditional type starter relay. The solenoid switch on a cranking motor closes the circuit between the battery and the starter. The attached schematic shows power from the ignition switch goes directly through the neutral safety switch and then to the starter solenoid.
Take a look at the schematic and you will see what I mean.
I hope this is helpful.
May 11, 2018 at 12:35 PM
