Take a look at the attachments for the oil pressure sender. This is under the distributor so I am not sure it is the issue but I would suggest cleaning off the oil and then starting the engine after you top the oil off and see if you can locate the source.
Here is a guide that can help with this as well:
https://www.2carpros.com/articles/engine-is-leaking-oil
Let us know if you have other questions or what you find. Thanks
Images (Click to enlarge)
Dec 17, 2020 at 10:24 AM
