Where is the nav SD card located?
122,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Got an error about the SD card and it asks to remove and reinsert it.
Aug 20, 2022 at 9:12 AM
SQM
  • 6,383 POSTS
The SD card should be located inside the center armrest/storage bin. If you open it and look towards the inside front, you should see the SD card slot.
See attached picture for reference.
Let me know if you are able to find it.
Aug 20, 2022 at 12:28 PM
BHAMDOC1973
  • 2,007 POSTS
No, there is not one. There's all plastic, one piece.
Aug 21, 2022 at 5:23 AM
SQM
  • 6,383 POSTS
Do you know if this is a euro or US spec vehicle?
Aug 23, 2022 at 1:04 AM
BHAMDOC1973
  • 2,007 POSTS
US.
Aug 23, 2022 at 1:17 AM
SQM
  • 6,383 POSTS
Some of the US models had the navigation module in the upper part of the glove box and they had a spot for the SD card on the module.
Aug 24, 2022 at 2:59 PM
BHAMDOC1973
  • 2,007 POSTS
Yes, i see this one. Se card on top of the module would mean it has to be removed cUse its mounted. The clickable removable part has the small battery in it. I unclicked and clicked it back fee times, it would start with the name of the device then goes to the error.
Aug 24, 2022 at 10:46 PM
SQM
  • 6,383 POSTS
It is possible that the module is bad. The only way to know would be to run a diagnostic using specialty scan tool. Which can communicate with all the electronic modules and test working orders.
Aug 26, 2022 at 3:53 PM
