Where is the lower alternator bolt on a shematic?
130,000 MILES • 2.0L • 6 CYL • 2WD • MANUAL
CHRISTOPHER SA
  • 259 POSTS
I am having trouble locating the part number for the lower alternator bolt. I can find the top one on diagrams (M10 x 150mm), but the lower bolt seems to be impossible to find.
Nov 13, 2025 at 10:17 AM
  • 55,858 POSTS
Yep, this can be tough unless you call the dealer, (it will be obsolete) but here is what I found
Lower alternator / bracket bolt:
Size: M8 x 105
BMW part number: 07 11 9 904 532 (often listed as 07119904532, hex bolt M8x105)
The upper / long bolt you already found (M10 x 150) matches:
Upper alternator bolt:
Size: M10 x 150
BMW part number: 07 11 9 904 677 (07119904677)
Practical tip for the job
Run a standard M8 x 1.25 x 105 mm class 8.8 or 10.9 bolt with a washer as a stand-in.
Let us know if you need anything else.
Nov 15, 2025 at 2:02 AM
CHRISTOPHER SA
  • 259 POSTS
Hi Ken,
Thanks for the response. I am a bit confused because the bolt that I have doesn't go through any other tensioner, pulley, or any other item. It bolts just the alternator to the engine/oil housing. The number you gave for the lower bolt seems to be for a pulley or different section of this area.
When taking the old alternator off, I noticed that the lower bolt was a bit longer than the top bolt (around 170mm) so kept them in different areas of my workspace so I wouldn't get them confused. But I did notice that they were both the same diameter - M10. But I may be mistaken in this. I just remember it was longer than the top bolt. I also noticed that it protruded out the back of the rear ear and nut quite a bit, so it could be that the alternator was changed prior to me doing it and someone put the wrong sized bolt back in.
The new alternator has a nut welded to the back of the lower rear 'ear' of the alternator and when putting the lower bolt back in it became extremely tight with more than 1/4" proud of the surface of the front alternator ear, before I stopped tightening for fear of stripping the bolt/nut thread. That means I have most likely cross-threaded the bolt which is why I am looking for a new one. The other reason I am having to replace the bolt is because there is some squealing coming from the belt, which tells me that there is a slight misalignment with the alternator pulley due to the bottom bolt not being tightened enough to prevent the alternator from moving around slightly, however slight it is.
The best thing would be for me to remove the alternator and actually measure the distance from the front ear to the back ear (outer surfaces) to confirm the approximate length. Not looking forward to that as it's quite cold here now. But when I do I will let you know the result.
Nov 15, 2025 at 2:27 AM
  • 55,858 POSTS
Sounds good, make sure the thread "pitch" so correct because if it is not it will strip the threads which is sounds like is happening. Let me know how it goes.
Nov 17, 2025 at 12:48 AM
