Where is the horn location under the hood
86,000 MILES
STEVE FILCHAK
  • 5 POSTS
this car is an R-title. It was hit in the front end. Every thing was repaired except the horn and radio. I can hear the relay click when I press the steering wheel. Can you tell me where the horn location is?
Jan 22, 2016 at 10:04 AM
WRENCHTECH
  • 20,760 POSTS
They are under the right front wheel well splash shield. http://i1198.photobucket.com/albums/aa448/Wrenchtech/horns%2006%20Zepher.gif
Jan 22, 2016 at 10:25 AM
STEVE FILCHAK
  • 5 POSTS
Thank you so much for the info Wrenchtech. I need a shop book. The car has no info booklets. Do you have the interiors fuse box location with the fuse/relay descriptions? I found the exterior fuse box and there's no info index inside for the fuses and relays
Jan 22, 2016 at 1:37 PM
WRENCHTECH
  • 20,760 POSTS
You should look into AlldataDIY.com. You can buy the same info we use for a single car for $27 a year. The interior unit is a Smart Junction Box, not just a fuse box. It contains modules and is programmable. Most of it's components are not accessible. It doesn't show me the location but it's probably under the dash on the driver's side. http://i1198.photobucket.com/albums/aa448/Wrenchtech/151886503.jpg https://www.2carpros.com/images/external/151655445.jpg
Jan 22, 2016 at 8:40 PM
