Where is the fuel filter located?
182,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
FAUGHNIX
Car starts and immediately rough idle and shuts off.
Apr 1, 2023 at 8:53 AM
  • 110,248 POSTS
The fuel filter is in the fuel tank and is serviced with the fuel pump assembly.
How often does this happen? I ask because a filter usually doesn't cause what you explained. If it is partially plugged, you are more likely to notice it when the engine is under a load and the fuel supply is increased.
Oftentimes, a rough idle and stalling at idle is the result of an engine vacuum leak. Have you checked for any leaks?
Here is a link that explains how it's done:
Also, read through this link and let me know if anything is helpful:
https://www.2carpros.com/articles/stall-at-idle
Apr 1, 2023 at 11:24 AM
