Where is the freeze plug located?
260,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WENDY BELLE ABSHER
The radiator froze up. When it unthawed water was leaking from underneath at the back of the motor.
Dec 27, 2022 at 4:51 AM
  • 55,673 POSTS
I don't know if there is a freeze plug in the rear of the engine. The only freeze plug I see is on the left side of the engine under the intake manifold. You might need to get the car up on jack stands or a car hoist to see where the leak is coming from then we can help you fix it; it might be the head gasket or thermostat housing. In the meantime, here is a guide that can help with the problem:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let us know what happens and please upload pictures or videos of the problem.
Dec 27, 2022 at 9:24 AM
