Where is the fan relay and temperature switch?
150,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JUSTIN JACKMAN
The fan doesn’t kick on. So I jump it straight to the battery to check it and the fan works.
Apr 15, 2021 at 12:39 AM
Good afternoon,
I attached the wiring diagram for you of the system and the location of the relay.
Try disconnect the coolant sensor and see if the fan kicks on.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Apr 15, 2021 at 2:49 AM
