Where is the ECM/PCM located?
210,000 MILES • 6.0L • 4WD • AUTOMATIC
HEATHERHARDIN0907
Need to replace the ECM, is it under the fuse box in the engine compartment?
Jun 11, 2022 at 4:13 AM
SQM
  • 6,383 POSTS
Yes, the ECM is located below the fuse box under the hood.
Remember to retrieve the existing ECM data before removing it, using an appropriate scan tool.
I have attached the replacement procedure as well as programming procedure below for your reference.
Let me know of any questions.
https://www.2carpros.com/articles/how-a-car-computer-works-pcm-ecm-bcm
Jun 11, 2022 at 7:42 AM
