Where is the drain plug located
1998 CHEVROLET ASTRO
288,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEANNEWRIGHT
I think I overfilled it. it keeps running hot, only overheating when I drive it but not redlining. could I have a blown head gasket now because of it?
Jan 13, 2019 at 9:52 PM
  • 110,244 POSTS
I'm not sure which plug you are referring to. If it is the oil drain plug, it is under the vehicle on the oil pan bottom. It will be facing the rear of the vehicle. If you look through this link, it shows an oil pan and the drain plug.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
As far as a head gasket, too much motor oil won't cause that.
Let me know if that is what you meant or if it is something different.
Jan 14, 2019 at 9:04 AM
