Where is the crankshaft position sensor located
209,000 MILES • 0.7L • V8 • 2WD • AUTOMATIC
LEEWI88IS
Turns over but don't start and when it does start like floods out and shuts off.
Jan 21, 2020 at 2:12 AM
Good afternoon,
When it starts, do you see fuel dumping into the intake manifold?
Chances are it either needs an ECM which controls the injectors, or the injectors themselves.
When you turn the key to the on position, do you see fuel coming out of the injectors?
Jan 21, 2020 at 2:50 AM
LEEWI88IS
No, no gas when you turn the key to the on position. But when you turn it over to start it you can see the fuel spraying out . is the a crank and cam shaft sensors?
Jan 21, 2020 at 6:00 AM
No, this is not a sensor.
Can you take a video of this while it happens?
I am wondering if it is the ECM or if you have a timing issue such as a bad timing chain.
Jan 21, 2020 at 6:03 AM
LEEWI88IS
Yea i am at work right now, but i will get a video made ASAP. thanks
Jan 21, 2020 at 6:08 AM
Sounds good.
By the way, there is no crank sensor since you have a distributor.
Jan 21, 2020 at 6:10 AM
LEEWI88IS
Jan 21, 2020 at 6:11 AM
You are welcome.
Jan 21, 2020 at 6:15 AM
