I'm getting an "Engine hot/AC off" message immediately upon turning the key, and the coolant temperature is pegged low.
Disconnecting the battery for a while temporarily cleared the condition.
I believe the coolant temperature sensor is either failing or has a bad connection. I need to know its location to be able to clean the contacts and/or replace the sensor.
Apr 11, 2023 at 5:13 AM
