My friend needs to replace the coolant temperature sensor on the car listed above SE model. Where is this sensor located? Thanks in advance!
Dec 8, 2019 at 8:31 PM
BMDOUBLE
✓Experienced Mechanic
It's located between #2 and #3 coil, I've attached a picture of it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
