Where is the transmission dipstick located ?
187,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
MIMOSA207
Location of the transmission dipstick needed.
Nov 30, 2021 at 10:35 PM
  • 110,248 POSTS
If you look down from the oil fill cap on the engine, you should see the dipstick for the transmission. It should have a yellow cover on its end.
I attached directions for checking below.
If your vehicle has a CVT transmission, let me know. However, I don't recall them being used on the 4wd models.
I hope this helps. Let me know if you have other questions.
Dec 1, 2021 at 12:07 PM
