Getting a lean code and thinking it's the MAP sensor. Check engine light blinks when I accelerate.
Mar 2, 2022 at 6:17 AM
✓Experienced Mechanic
If the light flashes, it most likely has a misfire. If you are getting a lean mixture, the first things to check are fuel pressure and an engine vacuum leak. Here are two links that explain how to do it:
