where is my fuel pump located?
300,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
DHELENA
Truck seems to run fine but seems to die after it warms up. There is crank but no start.
Jan 12, 2026 at 11:13 AM
  • 55,797 POSTS
Yep, this problem can be the fuel pump, ignition switch or the ignition module. Also, do you have dual fuel tanks, I have seen the fuel switching valve go out and cause this issue as well.
"The fuel pump is mounted on the fuel sender assembly inside of the fuel tank."
Please go over this video which can help narrow down the system that is failing when the engine stalls.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Please go over this guide and get back to us.
Jan 13, 2026 at 9:58 AM
