Where is location to disable air bag system
2002 CHEVROLET CAVALIER
163,455 MILES • 2.2L • 4 CYL
ENGNBLUZ
I need to replace my radiator on my car (SFI OHV). It says to disable airbag system in order for me to change the radiator. I do not know where to disable system from? Can anyone give me some insight to where its at on vehicle?
Jan 7, 2018 at 7:11 AM
STEVE W.
  • 15,347 POSTS
Disconnect the battery and let the vehicle set for about ten minutes and you will not need to worry about the airbags. Just be careful when you remove the radiator that you do not damage the wiring to any of the sensors up front and you will be okay.
Jan 7, 2018 at 8:45 AM
ENGNBLUZ
Thank you Steve, i greatly appreciate your time and help!
Jan 8, 2018 at 2:30 AM
STEVE W.
  • 15,347 POSTS
You are welcome. We will be here if you need any other help and thank you for using 2CarPros.
Jan 8, 2018 at 6:15 AM
