Where is fuse/relay for passenger side electrical window?
200,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
BENNYB43
I have an electrical motorized window issue on the front passenger side of the car. The window just one day is in the up position stuck. I think it is a fuse or relay that has gone bad. But I can't locate the fuse/relay that is bad. Any idea where the fuse/relay is and how to tell wich one it is?
Aug 20, 2021 at 2:24 AM
  • 110,248 POSTS
Power to the passenger front window is provided via fuse 10 in the under hood fuse box. If you look below, pics 1 and 2 are the wiring schematics for the power window circuit. I highlighted the wiring for the window you are having trouble with.
When you check the fuse, make sure it isn't blown. Also, make sure there is power to and from it. Here is a link to help:
Next, in the vehicle, under the dash near the brake pedal, is the smart junction box. Locate the delay relay 1. If relay 2 is the same part number (I think it is), switch them to see if the window works. If it is different, here is a link that explains how to test a relay:
Next, if the fuse and relay are good, I need you to go to the window switch and check to see if there is power to the red wire with a blue tracer. Here is a link that you may find helpful:
If there is power, then move to the motor and check for power at each of the two wires (one at a time) when the switch is actuated. If there is power, the motor is bad.
Note that the wiring schematic (pics 1 and 2) was originally one pic. I had to cut it in half to make it readable for you. I did overlap them so you can follow from one to the next.
Pic 3 shows the fuse in the under hood box and pic 4 shows the relay in the SJB.
Aug 20, 2021 at 2:27 PM
BENNYB43
Thanks, I was able to follow all your. instructions. looks like the motor is bad. Do you know how to take out the motor while leaving the window regulator in?
Aug 21, 2021 at 7:19 AM
  • 110,248 POSTS
The lift motor is basically just bolted on the regulator. Once you remove the door panel, which I believe you already have done, It should unbolt. Here is the thing. You need to support the glass and regulator to prevent the window from dropping into the door. The motor gears hold in place.
I attached a pic of the motor below. You can see the bolt holes.
Let me know if this helps or if I can help.
See pic below.
Aug 21, 2021 at 12:36 PM
BENNYB43
Thanks. Worked great.
Aug 21, 2021 at 12:50 PM
  • 110,248 POSTS
You are very welcome. I'm glad to hear you got it fixed.
Please feel free to come back anytime in the future if you have questions or need help. You are always welcome here.
Take good care of yourself,
Aug 21, 2021 at 12:52 PM
