fuel pump relay?
19,567 MILES
GAZAMAN
  • 6 POSTS
the car runs very good until u go above 3500rpms then check engine light comes on an when u do a computer diagonostic check trouble codes p1235 an p1238 comes up saying fuel pump out of range an fuel pump secondary circuit out of range i cant find the two fuel pump relays especially the secondary one can u help me
Jul 2, 2013 at 8:45 AM
FREEMBA
  • 1,152 POSTS
On your car this is what the P1238 means: DTC P1238: Mass Airflow Sensor Plausibility (Torque Monitor)
The 1235 means: DTC P1235: Mass Airflow Sensor Plausibility
(the definitions you gave in your post were for Ford vehicles)
Are there any mods on your vehicle? (often these codes are caused by overboost on turbocharged engines and/or drop in air filters) Here is a guide to help check the fuel pump relay with the location in the diagrams below.
Check out the diagrams (Below). Please run this test and get back to us.
Jul 2, 2013 at 11:16 AM
FORDMAN1966
Little power going to fuel pump. We have changed fuel pump and camshaft sensor. My husband could not find the relay to check it. he thought it may be that but does not know. please help ASAP.
Sep 11, 2020 at 6:10 AM (Merged)
HARRY P
  • 2,292 POSTS
Here is an image that should clarify it for you guys. Hope it helps. Let us know what you find.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The fuse #24 in the relay box, located left side of engine compartment is what feeds those two fuel pump relays. so you should start there making sure you have twelve volts on both sides of that fuse all the time.
LILFRANKY
How do I check if fuel pump is working and where do I locate relay?
WRENCHTECH
  • 20,758 POSTS
Use a fuel pressure gauge and test the fuel pressure. If no pressure, then you will have to troubleshoot the cause.
RENEE L
  • 1,260 POSTS
Hi LILFRANKY,
Here is a helpful link to an article from this site explaining the process of checking the fuel pressure yourself. If you decide you would like do this yourself you can purchase a fuel pressure gauge online from sites like Amazon.com.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
EBERTJOEL
I have a 2003 Mitsubishi Galant that will not start. It has spark so I looked for fuel problems. There is no power going to the pump. I replaced the relay and still no power at the pump. I used a jumper wire instead of the relay and the pump turns on but the car sill will not start. Why wouldn't power be going tot he fuel pump relay to activate it?
  • 75,988 POSTS
See diagram below
EBERTJOEL
This diagram didn't help me. When the key is in the on position there is 12 volts at fuse 13, but the relay doesn't turn on. I tested the relay to be good.
  • 75,988 POSTS
Check and test the violet wire on the relay to the computer controlled circuit could be open
EBERTJOEL
Ok, yes relay 2 (the top one) does not have a complete circuit, to what i assume is due to the computer leaving it open due to some other condition? I tested the ECU, something i read said to test the MAP sensor plug for 5 volts when the car is in the 'on' position to see if the ECU is working, it did so it should be working? Something else i read said it could be a bad crankshaft censor, i tested the ohms on the censor and i got 4 M ohms between 2 of the 3 connections and 0 between the others. Is this censor bad? If this censor was bad would it keep the fuel pump relay circuit open? If it was bad would i still have spark when i turned the car over?
RIVERMIKERAT
  • 6,106 POSTS
Most likely, no, you wouldn't have spark with a malfunctioning crank sensor. Fuse 13 is the source of switching power for the fuel pump relay. If that fuse is good, make sure there is power from it to the relay with the ignition on. The other side of that should be a path to ground. Make sure the other side of the switching side of the relay has a good ground.
TANK33
  • 6 POSTS
hey guys,i got the fuel pump out of tank,and it works when i straight wire it.now i need to know where is there fuel pump relay on this car 2003 mitsubishi galant.also just cause it work by straight wire does this means it should work while in the fuel tank.. thanks in advance
CARADIODOC
  • 34,415 POSTS
It should only run for one second after turning on the ignition switch. It will turn on again during engine rotation, (cranking or running).
TANK33
  • 6 POSTS
DO YOU KNOW WHERE THE RELAY IS FOR THE FUEL PUMP(2003 GALANT)
CARADIODOC
  • 34,415 POSTS
You're supposed to ask me something I know! :) If there isn't one labeled in the fuse box, look for an automatic shutdown relay. It might be called something else but it will be related to "engine", "fuel injection", or something like that. Before you go through all that work, listen under the tank while a helper turns on the ignition switch. If you hear the pump run for one second, that entire circuit is working. You must also check for spark when the fuel pump doesn't run during cranking. The most common no-start problems are caused by the trigger circuit that tells the Engine Computer to turn on the fuel pump AND the ignition coil through that relay.
ONEGREATGUY14
I have a 2003 galant with a 2.4 engine automatic. I can not get power to the fuel pump. all fuses and relays are good and there is no anti theft system. any ideas?
RIVERMIKERAT
  • 6,106 POSTS
Check for broken wires between the fuses and relays and the relay and pump. My reference doesn't list it, but there may be a fuel cut-off switch either in the trunk or in the driver kick panel area.
ONEGREATGUY14
I have search for the cut off switch in both places already and found nothing. I have conductivity in the wireing as well.... I was standing there next to the car and it just shut off.... im baffled??????
RIVERMIKERAT
  • 6,106 POSTS
Something ir wrong with my reference source. I'm unable to download images right now. I'm going to ask one of my colleagues to lend a hand.
Sep 11, 2020 at 6:11 AM (Merged)
  • 75,988 POSTS
Its the fuel pump relay no.2 that powers the fuel pump when the computer grounds the coil side of the fuel pump relay no2 thru fuel pump relay no.1
  • 75,988 POSTS
It sure is, dunno where I got that must be Mit1-lol-You have a nice day for me time to go to bed-its only 2150hrs 22 Dec
WRENCHTECH
  • 20,758 POSTS
OK Buddy. Have a great holiday if I don't talk to you before that.
RIVERMIKERAT
  • 6,106 POSTS
Thanks guys.
  • 75,988 POSTS
Merry Christmas to you guys too-thanks for all the help
CINDY MARTIN GRIFFIN
I am not getting power to the fuel pump. we have replaced the pump and checked the relays.
Sep 14, 2020 at 5:56 AM (Merged)
CARADIODOC
  • 34,415 POSTS
When are you checking? Have you checked for spark? Please list which engine you have.
2.4 engine. we are getting power leaving the relays.
Is there a kill switch?
CARADIODOC
  • 34,415 POSTS
You need to be specific. Are you testing at the fuel pump relay? The automatic shutdown, (ASD) relay? If you are testing for voltage at the connector for the fuel pump, you had better not have twelve volts there unless the engine is rotating, (cranking or running). The exception is you should see twelve volts there for one second when you turn on the ignition switch. If you are able to hear the hum of the pump for that one second when you turn on the ignition switch, the pump circuit is working.
About ninety five percent of crank/no-starts that involve a dead fuel pump also include no spark. That is why I asked if you have spark. Too many people get hung up on the first thing they find missing, and overlook the rest of the symptoms. You could have a problem in just the fuel pump circuit, but those account for perhaps one or two percent of no-starts.
There is no kill switch. "Inertia" switches are a troublesome Ford thing. Some other manufacturers might use them, but I am not aware of them. Other than that initial one-second burst, the Engine Computer turns on the ASD relay when it sees signal pulses coming from the crankshaft position sensor and camshaft position sensor. The ASD relay sends current to the ignition coil(s), injectors, oxygen sensor heaters, and fuel pump, or a separate fuel pump relay. This way, if a fuel line is ruptured in a crash, there will be no fuel pressure in that line. With no pressure, the engine cannot run. There will be no signal pulses from the two sensors when the engine is stalled. The computer turns the ASD relay off when there is no sensor pulses. That stops the fuel pump from dumping raw fuel onto the ground where it would be a fire hazard.
What and where is the ASD located?
CARADIODOC
  • 34,415 POSTS
Sorry for the confusion. Mitsubishi calls it the "multi-point fuel injection", (MFI) relay. The fastest way to test this circuit is to use a test light, and back-probe the red wire at any fuel injector, either of the two sensors, or at the mass air flow sensor. Digital voltmeters can work, but they respond too slowly to see the initial twelve volt pulse.
You should see the test light turn on for that first one second when you turn on the ignition switch. What is important is does it turn on again steady while you are cranking the engine.
The rest of the circuit is a little different than what I am used to seeing, so I am going to have to back up and study it. The ignition coils have their twelve volts switched on with the ignition switch, not any relay, so we cannot use them for any test procedure. There are two fuel pump relays. Fuel pump relay number one turns on any time the ignition switch is on. Fuel pump relay number two is the one that is turned on by the Engine Computer. They are in series, so both must turn on to have twelve volts to the pump. That will be on the white/black wire at the pump.
