Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Engine Cooling
Coolant Temperature Sensor
Where is exact location of Coolant Temperature Sensor?
2002 FORD WINDSTAR
98,500 MILES • 3.8L • 6 CYL • AUTOMATIC
FFALES
MEMBER
Need to replace Coolant Temperature Sensor.
May 8, 2021 at 3:55 AM
Experienced Mechanic
This sensor is on the top of the engine toward the rear. It should actually be in a cylinder head as they are technically called CHT, Cylinder Head Temperature sensors. Here is a guide that will help with this:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Below is the process from the manual. Please let us know if you still can't find it. Thanks
Images (Click to enlarge)
May 9, 2021 at 9:07 AM
FFALES
MEMBER
May 9, 2021 at 10:16 AM
You are welcome. Thanks for using 2CarPros. Please come back next time you need some info. Thanks
May 10, 2021 at 9:33 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
