Where is crankshaft sensor?
100,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
MARAUDERDB
I am looking to test the crankshaft sensor on my car listed above Cutlass Ciera with a 2.8l MFI engine. I cannot find the sensor anywhere. Where is this sensor located?
Oct 4, 2020 at 7:38 AM
You do not have a crank sensor on the crank shaft for this engine. Your sensor is in the distributor and the ECM uses the rotation of the distributor to determine engine position and RPM.
Take a look at this info. Let me know if there is an issue that you need this info for and we can try to figure out what the problem may be. Thanks
Oct 4, 2020 at 8:15 AM
MARAUDERDB
Thank you so much! I will look at it again tomorrow.
Oct 4, 2020 at 11:01 AM
you are welcome. You may have to remove the starter to actually get it out. I have not done it on this engine but it appears it needs to come out to get the sensor out. Thanks.
Oct 4, 2020 at 12:09 PM
