Where can I find the ECM on the car listed above Convertible Limited? I need to get the original ECM part number..
Jan 30, 2021 at 3:55 AM
SEVAG P
✓Experienced Mechanic
hello,
Engine control unit located driver side engine compartment, check the diagrams below.
Hope these helps.
thank you.
Images (Click to enlarge)
Jan 30, 2021 at 4:37 AM
MRBARNARD
MEMBER
Thank you! Those diagrams are different than ones I found. I was looking right at it but didn't know it was the PCM.
Jan 30, 2021 at 5:11 AM
SEVAG P
you welcome. let us know if you need more help.
Jan 31, 2021 at 2:01 AM
MRBARNARD
MEMBER
I do! Turns out, I can't find the number for the PCM so it can be replaced. Anyone know where it's supposed to be? The only number I located is part of the casting itself, which seems to be different than what is needed.
Image (Click to enlarge)
Jan 31, 2021 at 2:04 AM
SEVAG P
this number is the pcm part number 04829202ab of the picture that you attached. i will research to get your correct number.
Jan 31, 2021 at 2:27 AM
MRBARNARD
MEMBER
thanks again.
Jan 31, 2021 at 2:38 AM
SEVAG P
your correct PCM number is 5094318AD price 470.00$
