Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Diamante
Drivetrain
Transmission
Fluid
where do you top up transmission
1995 MITSUBISHI DIAMANTE
307,344 MILES • 2.4L • V6 • 2WD • AUTOMATIC
PETER MANA
MEMBER
1 POST
Would like to add fluid to prevent slipping
Jan 27, 2016 at 12:43 PM
HMAC300
Experienced Mechanic
it takes auto trans fluid DIAMOND SP or compatible. if fluid is dark brown or black and smells burnt have a trans guy rebuild it as that is probably the problem. must be between marks on stick for full on a level surface
Jan 27, 2016 at 10:20 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
